erro na instalação
Por: farofawoo
Em: 28/10/2006 13:19
A unica coisa que instala e o autodesk viewer, o programa mesmo num instala nem com reza braba :(. Ele deixa o log do erro na maquina aki 2006/10/28:11:52:12 Administrador HOME === Installation started on HOME by Administrador === 2006/10/28:11:52:12 Administrador HOME Install MSI Runtime 3.1 Skipped Windows Installer upgrade is not required. System Version = 3.1.4000.2435 2006/10/28:11:52:12 Administrador HOME Execute ..\support\directx\dxsetup.exe /silent 2006/10/28:11:52:12 Administrador HOME Running "E:\Installs\support\directx\dxsetup.exe" /silent 2006/10/28:11:52:14 Administrador HOME Install DirectX 9.0c Succeeded Command = "E:\Installs\support\directx\dxsetup.exe" /silent 2006/10/28:11:52:14 Administrador HOME Install .NET Framework Runtime 2.0 Skipped .NET Framework Runtime upgrade is not required. System Version = 2.0.50727.0 2006/10/28:11:52:14 Administrador HOME Execute ..\support\MS-Hotfix\NDP20-KB918842-X86.exe /quiet /l*v %temp%\3dsmax9_win32_Install.log 2006/10/28:11:52:14 Administrador HOME Running "E:\Installs\support\MS-Hotfix\NDP20-KB918842-X86.exe" /quiet /l*v C:\DOCUME~1\Administrador\Configurações locais\Temp\3dsmax9_win32_Install.log 2006/10/28:11:52:17 Administrador HOME Install .NET Framework Runtime 2.0 Hotfix Failed Failure is ignored, Result=1639 2006/10/28:11:52:17 Administrador HOME Execute ..\support\DWF\SetupDWFViewer.msi /qb 2006/10/28:11:52:17 Administrador HOME Running msiexec /i "E:\Installs\support\DWF\SetupDWFViewer.msi" /qb 2006/10/28:11:52:21 Administrador HOME Install Autodesk DWF Viewer 7 Succeeded Command = msiexec /i "E:\Installs\support\DWF\SetupDWFViewer.msi" /qb 2006/10/28:11:52:21 Administrador HOME Execute 3dsmax9_win32.msi /L*v %temp%\3dsmax9_win32_Install.log 2006/10/28:11:52:21 Administrador HOME Running msiexec /i "E:\Installs\3dsmax\3dsmax9_win32.msi" /L*v C:\DOCUME~1\Administrador\Configurações locais\Temp\3dsmax9_win32_Install.log 2006/10/28:11:52:22 Administrador HOME Install Autodesk 3ds Max 9 Failed Installation aborted, Result=1639 2006/10/28:11:52:22 Administrador HOME === Installation ended === o 8 também não funciona, da o mesmo erro. O erro que ta dando e tipo erro no windows installer, mas a gloriosa microsoft sabe que existe o erro mas não fala como resolve ¬¬...Cacei no google e nada tbm, quem puder ajudar eu agradeçoo e muitooooooooo
Oi Farofawoo, tudo bem? Então o problema está no seu Windows. O Max é um programa sensível, precisa de um Windows decente, bem instalado, sem estar zoado e lotado de coisas. O erro que está dando é por causa da imcompatibilidade com o instalador, atualize o seu Windows. Mas se eu fosse você, formatava a máquina e instalava tudo de novo do zero, para deixar realmente em ordem. Abraços
Usuário(s) on-line na última hora: 649
