Nvidia Quadro Fx580 ou Gtx460
Por: andersonflat
Em: 27/09/2010 12:59
e ai pessoal blz? tenho a duvida que a maioria dos designers tem, uma VGA quadro ou VGA gamer? atualmente faço mais maquetes e algumas animações. tenho uma gtx 260 e as vezes a viewport fica lenta se tiver com muitos objetos nela. segue as especificações delas: NVIDIA Quadro FX 580 Product Specifications * 512MB GDDR3 frame buffer * 128-bit memory interface * 25.6GB/sec memory bandwidth * DVI-I dual link and two DisplayPort * PCI Express x16 Gen 2 bus interface (compatible with Gen 1) * 40W maximum power consumption * No auxiliary power required * Active fansink thermal management * ATX form factor, 4.376” (H) x 6.875” (L) NVIDIA Quadro FX 580 by PNY Architecture * 128-bit color precision * 10-bit per color display pipeline * Unlimited fragment instruction * Unlimited vertex instruction * 3D volumetric texture support * Hardware-accelerated, antialiased points & lines * Hardware OpenGL overlay planes * Hardware-accelerated, two-sided lighting * Hardware-accelerated clipping planes * 3rd-generation occlusion culling * Window ID clipping functionality * Hardware-accelerated line stippling Shading Architecture * Full Shader Model 4.0 (OpenGL 3.0/DirectX 10 class) * Long fragment programs (unlimited instructions) * Long vertex programs (unlimited instructions) * Looping and subroutines (up to 256 loops per vertex program) * Dynamic flow control * Conditional execution High Level Shader Languages * Optimized complier for Cg and Microsoft HLSL * OpenGL 2.1 and DirectX 10 support * Open source compiler High-Resolution Antialiasing * Rotated Grid Full-Scene Antialiasing (RG FSAA) * 16x FSAA dramatically reduces visual aliasing artifacts or “jaggies” at resolution up to 1920x1200 Display Resolution Support * Dual DisplayPort support— ultra-high-resolution panels (up to 2560 x 1600 @ 60Hz) * Single dual-link DVI-I output drives digital display at resolutions up to 2560 x 1600 @ 60Hz nView Architecture * Advanced multi-display desktop & application management, seamlessly integrated into Microsoft Windows. Supported Operating Systems * Microsoft® Windows® Vista (64-bit and 32-bit) * Microsoft Windows XP (64-bit and 32-bit) * Microsoft Windows 2000 (32-bit) * Linux – full OpenGL implementation with NVIDIA and ARB extensions (64-bit and 32-bit) * AMD64, Intel EM64T Minimum System Requirements * PC compatible with Intel Pentium® 4/Xeon® or AMD Opteron® class processor or higher * Open PCI Express x16 lane slot * Microsoft Windows Vista, XP, 2000, or Linux * 512MB system memory * 50MB of available disk space for full installation * CD-ROM or DVD-ROM drive * DVI-D or DisplayPort compatible display * PCI Express Gen 2 support Geforce Gtx460 Performance NVIDIA GTX 460 720 MHz GPU 336 CUDA Cores 400 MHz RAMDAC Memory 768 MB, 192 bit GDDR5 3600 MHz (effective) 86.4 GB/s Memory Bandwidth Interface PCI-E 2.0 16x DVI-I, DVI-I, Mini-HDMI SLI Capable Resolution & Refresh 240Hz Max Refresh Rate 2048x1536 Max Analog 2560x1600 Max Digital o valor das 2 sao iguais R$ 699,00 qual compensa mais,? grato abçs
Se a sua máquina é só para trabalhar vá de Quadro, mas se ela tb serve para jogar ou ver filmes é melhor comprar a GTX460.
Quadro nao te dara o superte necessario em cuda cores(para iray real flow e etc) pelo msm preço GTX 460. Fica com Deus
Obrigado por tudo Senhor
Usuário(s) on-line na última hora: 598
