I have a huge problem in max
Por: pedro3822
Em: 16/07/2009 22:31
Hi Hope someone can help me because i have a huge problem! I have a file in 3ds max 2009 wich has 44Mb and is empty! I thought it was from some helpers that came from an evermotion scene but i deleted all in the layers and save again. I saw in the summary info from max and the scene doesn´t have anything and still has 44mg. The scene i´m working with has a lot of ivys as has 100mb but with this problem goes to 600mb and it takes years to open and save with a 8core xeon 2.8 with 8gb ram and fx quadro 3700 512mb I send this empy file with 44Mb so that you can take a look at it and try to help me so i can do it in my real file! I´m have to finish the job in 3weeks and put the video to render from exterior and interior. Another thing i have discover is that convert ivy with opacity maps from leaves to proxy it is not a good idea because lightcache takes years and i have put lots of ivys in the scene and now i had to model the leaves myself to attach to ivy and convert to proxy!I have now to put again lots of ivys in the scene here is the link to the scene http://rapidshare.com/files/256661176/1z.rar.html
Try to merge the file into a new empty max file! And should use max x64 version. cheers! http://sergiosena.carbonmade.com
http://www.arctipo.com.br
I use max x64 But in a new scene i need to adjust the lightning again and in the crazy scene the client liked the lightning...
Boas Estou a trabalhar numa cena que pesa actualmente 90mb, contudo fiz um merge dessa cena para uma vazia da evermotion somente aproveitando settings e luzes. Estava tudo a correr bem só que agora ao salvar a cena ela passou para 600mb. Experimentei tudo, inclusivé apagar tudo mas o ficheiro continuava a pesar 600mb e ao ir a summary info em file aparecia que o ficheiro ainda continha 20 helpers provenientes da cena da evermotion! Fui a caixa dos layers e apaguei tudo e realmente os helpers desapareceram!o problema é que ao salvar o ficheiro continua com 600mb!Isto é um desespero pois a cena demora anos a abrir e a salvar e a renderizar no vray. aqui segue o link da suposta cena que está vazia no interior mas que pesa 40mb http://rapidshare.com/files/256661176/1z.rar.html Espero realmente que me possam ajudar...estou mesmo a desesperar e tenho muito pouco tempo para entrega do trabalho (video3d exterior + interior)
Não posso baixar o arquivo agora para ver, mas por acaso tem algum biped na cena? Esse problema eu vi acontecer com biped e as poses dele que vão se multiplicando e o arquivo fica gigante.
o ficheiro neste momento está vazio!apaguei tudo dos layers e continua pesando 44Mb :(((((((((((((((((((((((((((( nao sei o que fazer!estou a entrar em desespero e tenho este trabalho urgente para entregar!!!
pedro, não estou certo disso, mas vale tentar.. Todas as veses que dou merge o tamanho do arquivo aumenta bastante naturalmente. Porque não tenta o merge invertido? Ao invés de pegar a cena da evermotion como base, e dar merge na cena com os ivys, tente dar merge da cena do evermotion em sua cena dos ivys, assim, acredito eu que o tamanho do arquivo final ficará menor.
Panades_max o problema é que eu queria usar os settings da cena evermotion e quando faço como tu dizes, mesmo copiando todos os settings, a lua nao fica igual como fazendo o inverso.
pedro, não conheço absolutamente nada do V-Ray para tentar te ajudar além disso, mas o problema é que sua cena dos ivys está com muitos objetos e quando usar merge na cena da evermotion, vai mesmo aumentar demais o tamanho em Mb do arquivo, deixando difícil de trabalhar com ela. Estou tentando pensar em algo mais aqui, caso encontre mais uma possibilidade posto novamente.
Dei uma olhada no teu arquivo e apesar de não aparecer nada, ele tem ainda 12 Archinteriors + 8 Archexteriors objetos na cena e 2 Particle View. Entrando nos layers, mandei seleciona-los de dentro da caixa dos layers, eles são selecionados na viewport e podem ser apagados, mas não dimunuiu o tamanho do arquivo. Tentei acessar o Particle view pra ver mas não há nada lá também. Desculpe pedro mas não pude ajudar como gostaria. Espero que consiga resolver o problema.
Usuário(s) on-line na última hora: 456
