Softimage | XSI -> Bugs
Por: Silvarudo
Em: 16/04/2007 17:32
Olá pessoal! Pra quem acha que é só o max que dá bugs, dá uma olhada nessa listinha de bugs do XSI. Como já disse em outro post, erro nestes programas é normal. O que não é normal, como disse o André, é eles não liberarem as correções para todos. The following is a list of Bug Fixes and Feature Enhancements in SOFTIMAGE|XSI v.6.01 Animation UDEV00235295 Constrained movement on handles using SHIFT does not properly UDEV00235596 Mixer: Storing character key sets should store all CKS in model UDEV00235646 remove animation > from all parameters any animation type, should not remove constraints UDEV00235917 Hierarchy from guide should not open MakeBiped PPG UDEV00235924 Fcurve Editor's explorer doesn't show all parameters in Flatten All. UDEV00236293 Copied Fcurve Keys can not replace keys using "Region Tools" UDEV00236440 FCurveSelection can crash XSI in HLE mode. UDEV00236536 FCurveEditor - "View Marked Parameters" should highlight explorer parameters in yellow UDEV00236538 FCurve Editor - New Preference required for Selecting Curves in the Explorer when in Selection Mode UDEV00236586 LINUX only - Segmentation Fault when saving a bvh *.tagt file UDEV00236657 Cannot copy slope angle and length of keyframe for start / last frame UDEV00236699 Performance slowdown when opening Animation Editor with large ActionClips UDEV00236700 Extra Undo steps for a slope when copying keyframe / Animation Editor UDEV00236701 Animation Editor : Allow copy\paste between multiple instances of XSI UDEV00236896 Errors on select and move a tangent, undo then move the tangent again. UDEV00236983 Using MMB to move a tangent sometimes moves it in the opposite direction. UDEV00236146 Frame Snapping requires undo\redo when opening FCurve Editor Converters/Import/Export UDEV00236016 3DS import does not always import .3ds file UDEV00236088 CrossWalk - 3dsMax - UI - Add an "Info" tab with a list of supported feature UDEV00236089 CrossWalk - 3dsMax - UI - Add the version number of Crosswalk to the plugin PPG. UDEV00236095 CrossWalk - Support Maya 8.5 linux UDEV00236280 Make XSI Crosswalk files use the Common Files directory Documentation UDEV00234921 SDK Doc - Operator.DisconnectGroup reference pages for Force parameter needs updating UDEV00235203 CusGuide: Information about how to install custom UFOs seems to be wrong UDEV00235621 Custom Renderer Plugin requires example General/Data Mgt UDEV00230194 DataMgt error: Model -> Convert to Reference, then crash when opening SceneRoot Mixer UDEV00236082 DataMgt Scene with glow, volumic or lens properties from 5.11 crashes XSI on load in 6.0 UDEV00236122 DataMgt Model exported with Camera animation in the mixer will crash upon reload. UDEV00236037 XSI crashes undoing preferences.General.undo UDEV00234402 XSI default c:\users directory conflicts with Vista defaults with domains UDEV00235691 Specific Scene built in 5.11 can crash on load in 6.0 UDEV00237219 Crash while saving after deleting objects from specific scene UDEV00237175 MakeModelLocal corruption when saving a specific scene UDEV00237214 Crash saving specific scene with Ref-Models with RBDs Reference Models UDEV00205155 Constraint on Ref-Model's top-level null or Sub-Model not supported UDEV00217198 AddModelSource command should not exist anymore UDEV00217376 Leaks when committing a Ref-Model with Constraints targeting externally UDEV00227567 Perfomance issue with active resolution of Nested Ref-Models UDEV00234057 Can't switch Active resolution of sub Ref-Model when a Parent Ref-Model object is constrained to a Sub model object UDEV00234259 Error Message when switching resolution of Ref-Model imported via Merge scene UDEV00234340 CharacterKey Sets lost after Commit to Ref-Model UDEV00235027 Ref-model preset doesn't load properly. UDEV00235028 Multiple deltas per model show many MsgBoxs. UDEV00235147 RBD - Change in the environment cache is not caught by the delta UDEV00235168 Delete Ref-Model, then Undo, Ref-Model mesh is not coming back UDEV00235301 Override properties are still applied when Delta is offloaded UDEV00235304 Ref-Model is offloaded when changing relative path of current resolution UDEV00235337 FND - renaming Ref-Models should be blocked UDEV00235378 External expression losing target model and doesn't reconnect at merge scene with conflicting Ref-Model name UDEV00235416 Errors adding a CharacterKey Set to Ref-Model UDEV00235418 Sub CharacterKey set added to Nested Ref-Model are not reconnecting at load scene UDEV00235556 Scripted Op disconnects when updating input Ref-Models when output is a Ref-Model too UDEV00235595 External deltas on nested models sometimes crash on load UDEV00235610 Paste Animation on constraint doesn't update Delta. UDEV00235732 Some XSI 5.11 scenes fail to open on linux UDEV00235781 Ref-model cameras not reliable in render farm. UDEV00235782 Scripted Op doesn't support change of script engine UDEV00235872 FCurves are not Commited to Ref-Model UDEV00235873 Synoptic are not persisted when Updating the Ref-Model just after adding the property UDEV00235891 Linked shape weights and clip weights lost in reference models related to mixer UDEV00235892 Delta not updated when constraining object is renamed UDEV00235921 Lost added properties at MakeModelLocal UDEV00235997 Export model can cause xsi to crash UDEV00236019 XSI can crashes when opening some Linux files UDEV00236023 Add a layer (on ref. model) and set keys on it, save then reload the scene and keys on the new have disappear. UDEV00236025 Import a ref. model, save your scene then add a new Animation Layer or select Models can crash XSI UDEV00236031 XSI can crash saving a scene with Ref-Model objects in scene layers UDEV00236033 XSI crash sometimes when setting keys on a Layer inside a referenced Model. UDEV00236045 Scene explorer refresh problem when loading resolution through the Ref-Model PPG UDEV00236214 NameSpaces not apparent in Deltas UDEV00236219 Duplicated Local model with Nested Referenced Models are sometimes corrupted UDEV00236284 Error message not clear when trying to render a scene through a camera inside an offloaded Ref-Model UDEV00236300 Scene becomes bigger when saving a scene with a Ref-Model and many objects hidden UDEV00236384 Mixer stays Ref-Model locked after Make Model local UDEV00236400 Error updating a resolution of a Ref-Model with an Fc expression UDEV00236421 Expression not reconnecting when set on a Mixer's compound weight track UDEV00236593 Opening 5.11 scene in 6.0 can result in animation loss UDEV00236643 Import a Ref.Model and duplicate a Shape on the Shape Manager can crash XSI UDEV00236662 Only one mixer is applied to all Ref-Models UDEV00236722 XSI crash when adding a Link Deform with Orientation on an object inside a Ref. model UDEV00236778 Crashsaving a scene with ScriptedOp on Ref-Models UDEV00236843 XSI crash when "Add empty delta" to a Ref. Model then Make the Ref. Model Local UDEV00236901 Crash loading specific 6.0 scene with Ref-Models UDEV00236969 Scene file can get inflated every-time you save scene UDEV00235692 XSI 6 mixer crash when splitting clips with Ref-Model Rendering UDEV00235383 Hardware rendering in OpenGL doesn't render textures UDEV00223456 If pass is changed with Pass Preview window open, it will not refresh with new render settings. UDEV00227256 Shaderball: Need to be able to preview real-time shader. UDEV00233920 Changing the current UV updates the shaderball UDEV00234168 Update the scntoc syntax to accept the new render output structure UDEV00234283 Progress bar for the total render time in render viewer UDEV00234326 Support Lens Shaders on passes UDEV00234463 Render Region ignores playback UDEV00234969 Crash when pluging in architectural shader into materials displacement port UDEV00234997 Render Region missing "Set Pass Crop from Region" button UDEV00235001 Field Rendering should be part of Output Format UDEV00235003 MXF list on Output Format ppg does not update correctly when switching presets UDEV00235012 Output Format Preset switch on Scene Render Options does not update scene items properly UDEV00235184 Framebuffer list not synchronized with changes done in framebuffers' PPGs UDEV00235232 Render Preview can cause crashes and UI unresponsiveness UDEV00235344 Particles and rigid bodies do not render correctly if start frame is higher than 1 UDEV00235348 Not possible to override output resolution in pass UDEV00235352 Change the default region/preview format to Softimage pic format UDEV00235381 Region Copy Options inactive in Renderer Options UDEV00235391 Crash working with render region open and hair (when display type set to Render Hairs) UDEV00235443 Satellite rendering needs updating UDEV00235489 Physical_sky and Physical_sun need to be texturable UDEV00235494 Pass camera sometimes not updated when scripted UDEV00235513 Error creating and rendering multiple framebuffers based on the same render channel UDEV00235514 Hardware rendering is broken on Linux UDEV00235550 Update xsibatch to the new rendering structure. UDEV00235562 mental ray doesn't write out FG or photon maps UDEV00235578 Cannot connect nodes in Render Tree if zoom is not 100% on Linux UDEV00235593 File format tooltip assert after switching to hardware rendering UDEV00235603 Wrapper shader for the MI architectural shader UDEV00235645 Render region does not react to motion blur settings in scene render options UDEV00235648 Glow pass doesn't render glow UDEV00235685 Aborting a render event can put XSI in an endless loop UDEV00235686 Single frame rendering should append the frame number to the filename UDEV00235762 Crash when connecting 'mia_round corners' into displacement UDEV00235774 Deleting layer can cause errors UDEV00235923 Viewport zoom should not affect pass rendering, only the render region UDEV00235935 -skip on|off doesn''t work on linux xsi6 ( xsibatch ) UDEV00235955 Volume_fog not working properly with transparent map UDEV00235956 Rendering in Object View renders all objects in the scene UDEV00236205 Scaling hair and other groom tools does not update region UDEV00236215 Export 2 MI2 hangs on Linux UDEV00236252 Advancing the timeline in the FCurve Editor disables the Render Region display UDEV00236259 RenderVertex fails for large meshes UDEV00236271 Hiding lights not supported by architectural_material UDEV00236282 Architectural Material crash XSI when connected to Material Environment and Volume UDEV00236347 Loading a Pass as a preset can crash XSI UDEV00236406 Crash when Skim_Milk attach to Surface and Shadow with ShaderBall UDEV00236438 Bad Spdl logic in region options for Motion Blur and Multi PPGs UDEV00236617 scripting backcomp - Crash changing hardware color background parameters UDEV00236619 Invalid output paths are gone when loaded into v6.0 UDEV00236668 Add 'ZBump' to sibase and rendertree UDEV00236669 No indication in the xsibatch help output that -render && -script can be used together UDEV00236671 "xsibatch -script -" tries to read the console input as wide string UDEV00236680 Render Stops unexpectedly when rendering with skip frame UDEV00236697 XSIBATCH should report actual frames rendered .. and not skipped ones UDEV00236718 Can't render anything in specific scene UDEV00236756 Overwriting current pass's values with a preset does not update materials/overrides UDEV00236822 Motion vectors should be written out in raster space UDEV00236894 Multiple Custom Renderer Options UDEV00236947 No animated deforms in Hardware Rendering UDEV00237060 mental ray binary archives broken Scripting UDEV00235158 SDK Doc: Event documentation incomplete UDEV00235770 Create New Upvector broken on Linux UDEV00235813 Parameters not visible in UI also invisible to scripting UDEV00235529 Python seems to be liked against libstdc++5 SDK UDEV00072332 RefGuide: ShapeKey object missing example UDEV00190623 RefGuide: Syntax Errors in some OM examples UDEV00193850 RefGuide: Example for InstallAddon needs to be updated UDEV00235039 SDK - C# custom ops lock up XSI in rendering UDEV00235368 SDK function required to get a list of frames to render UDEV00235409 Events | Filename attribute not accessible for BeginSequence / EndSequence events UDEV00235751 incorrect inputs generated in code by sdk wizard UDEV00235808 SDK: Linux: CPP Plugin wizard don't create GNUMakefile anymore UDEV00236166 PlayControl.Current does not return the correct time when rendering. UDEV00236243 XSIFactory.CreateObject not able to create shader objects UDEV00236426 SDK function to get resolved archive filename from the Pass object UDEV00236427 SDK function to resolve token strings UDEV00235740 SDK Plugins are now exposed to multi-threading Setup UDEV00235334 misleading SPM warning on uninstall should be removed Texturing UDEV00235340 Texturing TE shows no texture when opening with polygon selection UI UDEV00234621 XSI linux32 version crashes on launch when run on Linux64 OS. UDEV00235195 Linux - UI Glitch when moving XSI floating window over Main window UDEV00235464 Render Tree font size too small in XSI 6 UDEV00235679 Can not launch XSI if you set a default layout that has ObjectView UDEV00235695 Color Sampler shader should not be using Japanese string for texture name UDEV00235753 XSI 6 shows 5.11 splash screen and 5.11 in about UDEV00235791 Icons required for SceneExplorer renderer properties UDEV00235855 Autohide layout : MCP can crash on load UDEV00236173 Custom commands in contextual menus missing UDEV00236202 XSI 6.0 viewport clusters material defect (64bit only) UDEV00236953 Linux - grid mouse tool tips display empty info Viewing/Interaction UDEV00235825 Rotoscope does not scale the image to the proportions of the viewport when loop icon is pressed Falow!
Vixe, se o xsi tem isso tudo de bug tu imagina o max sem sp !!! auhahuauhauha , seriam o que...umas 100 paginas ? uhauhauhauha vlw !
Oi Silvarudo, tudo bem? Foi uma ótima idéia fazer isso, 10 a 0 para você!!! Assim, os novatos vão perceber que é normal os grandes softs de 3D sairem com bugs, então, não é só no Max que é imbecilidade sair usando profissionalmente uma versão que acabou de sair, até no XSI é imbecilidade e o XSI é o progama 3D mais poderoso do mundo. Tudo bem que essa lista está maior do que deveria, porque o XSI é multi-plataforma e os bugs listados se referem a todas as plataformas, o que não é o caso do Max, que só roda em Windows. Mesmo assim, mostra a quantidade de bugs que o melhor programa 3D do mundo tem, imagine o Max então, como disse o Thunndro. Sempre tem que esperar sair as correções, quando o soft é lançado tem que usar para brincar, para testar, para fuçar e ver quais são os problemas, até para poder saber se foram corrigidos quando instalar o Service Pack. Só depois do Service Pack que dá para usar profissionalmente sem sustos. Como o Thunndro comentou em outro tópico, o Max 9 estava até corrompendo arquivos dele sem o SP. Imagine se ele está fazendo um trabalho profissional e corrompe o arquivo, numa empresa grande e conceituada como a que ele trabalha. Imagine então se o trabalho tem um prazo curto para entregar e perdeu o arquivo quando estava quase no final. Nenhum profissional quer correr esse risco, por isso que todos esperam o SP. Abraços
Usuário(s) on-line na última hora: 702
