Não aguento mais esse erro!!!prq?!!!
Por: SaavedraCG
Em: 31/03/2008 00:09
FAla galera!! Não aguento mais v esse erro quando habilito o caustic no MR:( Alguem pode me ajudar?!!! Quando estudo com a cena do curso de mr nao acontece nada..mas quando vou criar uma cena nova simples..como um plano uma esfera e uma luz da esses erros. Antes q alguem pergunte eu habilito o caustic da esfera...nela coloco um material dialetric. Aqui esta o Erro:( RCGI 0.5 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.6 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.5 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6b7) RCGI 0.6 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6b7) RCGI 0.4 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.4 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6b7) RCGI 0.3 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.7 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6b7) RCGI 0.6 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.6 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6b7) RCGI 0.5 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.5 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6b7) RCGI 0.7 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.7 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6b7) RCGI 0.4 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.6 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.5 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.7 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6b7): canceling emission job RCGI 0.3 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.7 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6d7) RCGI 0.5 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.5 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6d7) RCGI 0.6 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.6 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6d7) RCGI 0.4 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.4 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6d7) RCGI 0.7 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.7 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6d7) RCGI 0.5 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.5 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6d7) RCGI 0.6 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.6 warn 362004: no photons stored after emitting 10000 photons from light "Spot01|Light" (tag 6d7) RCGI 0.4 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.7 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.5 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job RCGI 0.6 error 361053: no photons stored after emitting 1000000 photons from light "Spot01|Light" (tag 6d7): canceling emission job
Cara, esse erro só acontece quando a pessoa está começando e não sabe configurar direito o Caustics. Porque depois que aprende nunca mais acontece. Comigo acontecia direto também, mas depois que estudei as aulas de Caustics do curso da 3D1 eu aprendi. Precisa de 3 coisas pro Caustics funcionar. 1- O objeto tem que estar habilitado para gerar Caustics na aba Mental Ray da janela Object Properties. 2- O material tem que ter shaders que controlem os Photons. Se você não sabe criar materiais no Mental Ray, use o material Raytrace que vai dar certo, porque ele configura os Photons automaticamente. É só colocar um material Raytrace com branco no transparency que vai criar o efeito sem problema. 3- Todas as luzes da cena tem que atingir o objeto que cria o Caustics. Se só uma luz da cena atinge o objeto, nas outras vc tem que zerar o Caustics Photons no menu do mental ray que aparece nas luzes. Fazendo estas 3 coisas, nunca mais vai dar esse erro!!!
esse erro é bem simples!! isso é uma cena aberta!! e os photons estão indo pro espaço!! experimente colocar uma esfera grande envolvendo a cena!! ai nessa esfera use o modifier normal pra inverter as faces!! e refaça o teste
Fala galera!!! Supermax- cara segui o tuto do curso de MR daqui...Fiz tudo q vc falou..e não funfa. Coloquei o dialetric seguindo o tuto de caustic do curso..fiz tudo como o andre´falou...so q quando vou fazer uma cena do zero da esses erros mesmo com as configurações q tem no video. Rogério- Valeu pela dica....mas no curso do MR o andré não usa nada ao redor e da certo:D Será sempre vou ter q usar essa redoma
no photons stored significa que os photons não esta sendo guardados!! isso acontece sempre qd os photons se perde no espaço!! realmente não precisa ter uma redoma pra gerar o caustic!! tu não habilitou o GI tb não?
O erro dos Photons se perdendo no espaço vai acontecer com GI, com Caustics não! 3D Designer, vc fez o teste com material raytrace normal? Se der errado com material raytrace normal é bom você ver o curso de novo. Se der certo, ai tudo está certo, o problema é no material, provavelmente está sem shader no slot photons. Tem uma hipótese para tudo dar errado com você. Se mexer nas configurações do Customize>Units Setup>System Units Setup. Ai nem o Mental Ray e nem nada funciona direito.
eu testei aki!! com um plane e uma esfera deu erro com redoma e sem redoma!! vc colocou algum material no plane? aki fois só eu colocar que o erro sumiu e renderizou certinho!!
Rogério- Cara não habilitei não...no teste do curso nao tem gi nem FG...e rola tranquilo...o André só habilita o caustic.. Supermax- Vou falou:2- O material tem que ter shaders que controlem os Photons. .. Tudo bem...pra testar,copiei o dialetric q estava no surface para o canal de photos(não sei se esse é o certo) mas pegou blz....mas oq me intriga é q no vídeo do andré ele não coloca nada no canal de photonso faz como eu fiz..coloca um dialetric material no surface pega blz:S
Supermax- Com um material raytraced pega blz;) MAs quero testar com o dialettric também.
Eu tenho o curso e estou estudando esse capítulo. O André usa o shader glass que é igual ao dielectric, mas como ele fala no curso, esse shader já vem com uma cópia no photons. Lá ele mostra que pra fazer um material igual com o dielectric, tem que copiar para o photons, é impossível de funcionar com um material mental ray sem nada no photons. O que ele faz lá é configurar o material raytrace para criar vidro e coloca o dielectric no surface do mental ray connection, só não não usar a aparência do raytrace e fazer o vidro com dielectric. Ai funciona porque o material raytrace está configurado pra fazer vidro e vai criar caustics. Assiste o vídeo de novo, vc não assistiu direito!!!
Usuário(s) on-line na última hora: 1091
