final toon
Por: danieldt
Em: 02/10/2006 15:49
Olá amigos. alguem aqui tem o final toon instaldo no max 7? o meu esta dando um erro 127 e não abre nem a pau. No site da cebas diz: error code 127 If you get the above error message it is very likely that you have installed the wrong version of the plug-in for that 3ds max release. Only 3ds max 6,7 and 8 are able to use the same plug-in version all other versions of 3ds max must have their special compiles of the plug-in to work with. Another case for this error may be a false loading order in the plugin.ini file of 3ds max. It is known that 3ds max 8 has a bug that causes the plugin.ini entries to shuffle randomly around. Make sure the correct loading order is always present in the plugin.ini. Last update: 2006-02-21 13:47 Author: edwin Revision: 1.0 .. mas realmente não vi ai algo para que solucionasse o problema. Alguém pode me ajudar? Um abraço!
www.viartualisar.com.br Realidade aumentada 3d fotorrealista
Usuário(s) on-line na última hora: 707
