Dúvida: Objetos arredondados no CAD aparecem com faces no 3DS MAX.
Por: GuilhermeD
Em: 23/03/2017 14:45
Em uma duvida semelhante que vi na internet citou que eu deveria mudar o facetres no CAD para o máximo, já fiz e não adiantou. alguém consegue me ajudar nessa treta?
problema resolvido
3dsmax menu -> Import -> Link AutoCad (click browse to find your .dwg)
Attach the file, then go to the next tab and make sure \'Show reload options\' is checked.
Then press reload.
In the \'File Link Settings: DWG options\' window;
Set curve steps to 100 and maximum surface deviation for 3D solids to 0.1mm
I usually uncheck all the other stuff on all tabs, and leave defaults for Spline rendering.
Just a note: Make sure there are no \'Ray\' lines in your AutoCad dwg. 3DSMax doesn\'t seem to like the concept of infinite lenght lines and will freeze up.
pode fechar
Usuário(s) on-line na última hora: 335
