pc xeon E5540 x I7 950
Por: lpomaro
Em: 15/12/2009 11:10
Seguinte galera ...com ajuda de vcs montei dois pcs ..um xeon bem simples (fx1800) e um I7 mais robusto(fx 3800) em relacao custo x beneficio qual valeria mais aplicacoes mais de 3d max e cad ... 1: MAINBOARD: Tyan S7002G2NR, Dual LGA1366 Sockets, Intel Tylersburg 5520 Chipset, 8xDDR3-1333 DIMM, 2xGiga LAN, 6xSATA-II Raid 0/1/10/5, Realtek ALC888 Sound, 4xUSB POWER: 850W (1020W Max Output) Cooler Master (Silent Pro M850 Modular) ATX / EPS PSU, Ultra-Silent 13.5cm Fan, 85% Efficiency, SLI, 80Plus Certified CHASSIS: Medium Tower - Black, Coolermaster 690, 4 x 5.25 & 5x3.5 Drive Bays, 2 x 12cm Front/Rear, 525x 213x 482 (D x W x H ) XEON CPU: 2 x Intel Xeon Processor E5504 Nehalem Quad Core - 2.00GHz, 4MB CACHE, 4.8GTs, LGA1366 CPU FANS: 2 x Thermal Solution (Active) up to E5540 DVD-BLU: 24x Dual-Layer Burner (DVD±RW, CD-RW), SATA ACTICA MEMORY: 6GB (6x1GB) DDR3-1333 MHz 240 DIMM, Registered ECC HARD DISK: 1 x Hitachi Deskstar 500Gb SATA-II, 7200RPM, 16Mb RAID SETUP: Please Select VGA PCI-E: 768MB, NVIDIA Quadro FX-1800, GDDR3, 192-Bit, 2 x Display Port, 1 x DVI-I preco : au$ 2980.00 2: PROCESSOR: Intel Core i7 950 (3.00Ghz) 8Mb Cache, Quad Core, LGA1366 MAINBOARD: Intel X58 Chipset - LGA1366 - 6 x Triple DDR3 - PCI-E 2.0 - SATA RAID - HD Sound - 2 x Gigabit LAN (Gigabyte GA-EX58-UD5) CHASSIS: Medium Tower, 650W Quiet Power Supply, 9 Drive Bays, Advanced Cooling System - 3 x Fans, Top USB (Cooler Master 690) MEMORY: Kingston 12Gb, DDR3, 1333Mhz, Triple Channel HARD DISK: 1 x WD 500Gb SATA-II, 7200RPM, 32Mb Cache RAID-SETUP: NO RAID SETUP VGA: 1GB, NVIDIA Quadro FX-3800, GDDR3, Dual Display, 2 x DVI-I + DP + ST MONITOR: NO LCD MONITOR DVD-RW: 24x Dual Layer DVD±RW Recorder & Software, Black preco : au$ 3.489,00
cara...vai no xeon, sem sombras de duvidas, de olho fechado...
"lpomaro" disse: XEON CPU: 2 x Intel Xeon Processor E5504 Nehalem Quad Core - 2.00GHz, 4MB CACHE, 4.8GTs, LGA1366
Se vc deseja performance pra render, compre no minimo o 5520, pois ele tem hyper threading (vc terá 8 buckets por processador, no caso com dois processadores, 16 buckets). O 5504 é um quadcore comum, sem essa tecnologia e mesmo com dois processadores vc terá "apenas" 8 buckets no total.
Entre esses dois o Xeon por um simples motivo, a hora que você puder, compra 2 E5520 que você terá 16 núcleos de processamento. Porém, se você puder fazer isto agora melhor ainda. Qual a diferença entre o E5520 e o E5504? Pense da seguinte forma, já que pelo que você postou você pode gastar AU$500 a mais com o i7 do que com o Xeon, então se a diferença entre os dois modelos Xeon supracitados for aproximadamente esta, não tenha nem dúvidas compre o E5520. E memória, aqui no Brasil não está tão caro quanto um processador Xeon, apesar dessas serem ECC.
entao , se eu pegar esse xeonE5520 , mesmo com menos ram(consigo pagar 6gb) e com a placa quadro fx 1800 continua sendo melhor opcao q o i7950 com 12 gb de ram e quadro fx 3800?? eu digo ... essa placa 1800 e realmente boa no render?? obrigado
"lpomaro" disse: entao , se eu pegar esse xeonE5520 , mesmo com menos ram(consigo pagar 6gb) e com a placa quadro fx 1800 continua sendo melhor opcao q o i7950 com 12 gb de ram e quadro fx 3800?? eu digo ... essa placa 1800 e realmente boa no render?? obrigado
A quadro não irá influenciar no render. Vc só notará diferença na viewport. Quanto a memória, é altamente recomendado que vc pegue, mesmo no xeon, 12gbs. Hj em dia quanto mais melhor, e memória não é tão caro como uma placa de vídeo por exemplo. Opinião pessoal agora, uma quadro 1800 parece suficiente pra mim, a 3800 é absurdamente mais cara. Pra vc ter uma idéia, atualmente estou com uma GTX260 (nem quadro ela é) e veja na imagem anexada que eu estou trabalhando com aproximadamente 50.000.000 de poligonos nesta cena (33.000.000 nos objetos selecionados e mais uns 20.000.000 em particle flow). Perceba que não há NADA em display as box e todos os objetos mostram suas texturas. A fluidez da viewport (frames por segundo) é baixa, admito, mas é perfeitamente "trabalhavel", não da nenhum pau, travamento, zica e afins. Enfim, moral da história, talvez não haja real necessidade em gastar uma fortuna numa quadro 3800. A não ser que vc vá trabalhar com 100 milhoes de poligonos na viewport.
esse tópico me intereça, mas a img do LG não esta aparecendo :P
É por isso que eu digo que no custo benefício as geforce dão um banho... imagina uma GTX285 nesse caso, quem sabe subisse pra pelo menos 1fps... :-P
velho, vá para o xeon, no meu caso, eu tenho o xeon exatamente com aconfig que LG falou ( intel (R) xeon (R) CPU E5520 2,26GHz (2 processadores + 12 gigas de ram e 4 tera de hd+ placa quadro 3800 + 2 monitores de 23 pol) , trabalho com 16 buckets na tela, meus renders hj não demoram mais que 40min. e olhe que eu exagero nas arvores , texturas reflexos , etc.... custo aproximado : 12k na CPU e 1,3k nos monitores. se valeu a pena? valeu demais, tempo é dinheiro... antes o render demorava 5 as vezes 20 horas em 4 quadcores em rede. agora tem um detalhe, se for pra fazer um investimento desses e cobrar preço de amador, não entre.... vlw
Marcoviana ... Cara , nao cobro preco de amador , na verdade nao vendo maquetes digitais ainda .... Sou arquiteto e estou entrando no mundo do 3d nao faz mto tempo ... na verdade , logo voltarei para o brasil e farei cursos como melies para me expecializar mais e ai sim comecar a cobrar como tu ....mas penso em montar uma maquina boa para isso , ja que estou na australia e esse computador saira pra mim uns 4 mil 500 reais , nao chega a 5 ....e acho q no brasil nao compro nada parecido com isso ....tu acha q e um disperdicio gasta tudo isso se nao sou um pro em 3d ainda??
Usuário(s) on-line na última hora: 668
